Old 12-01-2011, 02:35 PM
Rawkkrawler's Avatar
Rawkkrawler Rawkkrawler is offline
Cobra Make, Engine: Everett Morrison
Default Holley 4778 Question
I just picked up a 700 CFM (List 4778).
I'm going to rebuild it and could use some advise.
Engine is a 428 with a max torque @ 4100 RPM and max horsepower @ 5300 RPM. With an efficiency of 90%, the 700 CFM seems right.
Jets - 66 primary, 71 secondary
Powervalve - 3.5 lb. (Manifold vacuum is 8lbs at idle)
The carb has a 31 primary and 32 secondary squirters (Should they be 35-40 with the power/weight ratio?)
What color accelerator pump cams should I start with?
Mike D
Tampa Fl
