Old 12-07-2011, 09:27 AM
Keithc8 Keithc8 is offline
Default Keith Craft 358ci.Shortblock $1995.00
This is a freshly built Ford 351W 358ci Shortblock. This block has been baked, tumbled, crack checked, bore and honed w/ torque plates, blueprinted deck, line honed, lifter bores honed, new cam bearings, new freeze plugs, painted and prepped for assembly. This shortblock includes: Felpro one piece rear main seal, ARP main studs, Eagle 4340 Steel 3.500" Crankshaft, Eagle 6.200" H-Beam Rods, JE Dome Pistons, JE Wrist Pins, Federal Mogul Heat Treated Bearings, and Mahle Plasma Rings. You can use a 70-72cc head if you would like to use pump fuel, if you want to run race fuel and some compression you can run a standard 58-60cc head. This would make a great foundation to your project.
Please call with any questions 870-246-7460
Keith C
