Old 12-07-2011, 09:17 AM
Mark O'Neal Mark O'Neal is offline
Originally Posted by DAVID GAGNARD View Post
Using Holley's formula for determining carb cfm requirements of a given engine (cubic inches X max rpms diveded by 3456) assuming a 6000 rpm redline, your engine would need 574.66 cfms of air, also, assuming 100% VE....Add in antoher 50 cfm so you don't max out the carb and you need 624.66 cfms of air, so a 650 double pumper would be perfect....you would have good idle vacum and good low end torque as well as enough carb to see it through the rpm range......
a lot of times when it comes to carbs,bigger is not better.....
David
I used to use that formula, with pretty much the same result.
Then I found out the motor made more power with a 780.
