Old 12-09-2011, 03:49 AM
Rob. Smith Rob. Smith is offline
IMG_3535_1 - Club Cobra Photo Gallery
G'Day Craig,
Thanks for your reply. My engineer told me to talk to Norm Thorogood. He was the brake and suspension man for the Geoghans and for Gricey. Norm suggested that I should blank off the front port and use the second port to tee off, and work both front calipers...This works ok. I'm really looking for the pedal ratios for my records.. as well as looking at after market pedals because I have fitted an internal hydraulic clutch throw-out bearing and can't get correct pedal travel unless I raise the pedal 50mm higher than the Brake pedal. That is not an option. If you look at the pic you can see the front lower port has a plug in it
Still trying to 'successfully' attach pics.
