Old 12-15-2011, 12:59 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
I replaced the seal in a 351 last month. I use an adapter to blow air into the cylinders. I borrowed a tool to compress the spring and a magnet to remove the keepers. A third hand makes it a lot easier. It took about 1 1/2 hours to replace the seals.
Dwight
When you remove the intake, drain the oil first or plan on new oil when you finish.
