Old 12-15-2011, 05:30 PM
sjp sjp is offline
Cobra Make, Engine: Shelby 427 c/o
Your frame should have two holes in upper center of the frame I believe the holes should be tapped for 2 mm screws at least the originals are, you might be able to use screws from an eye glass repair kit, you can go to a hardware store they will probably have what you need. Some of the repros use drive rivets that look like screws.
Sam
