Old 12-19-2011, 07:27 PM
patrickt patrickt is offline
Default You Have Two Choices
You have two choices -- pull the hoses off each end of the bung tube and pull the tube out, or pull the hoses off the other ends and pull the whole two hose one bung tube assembly as a single unit and then pull the bung tube out while it's on your work bench. If you do that, use a Sharpie to mark the orientation of the the bung tube to the two hoses before you pull them.
