LJ,
I have always bought Willwood master cylinders and have used them for years without a problem. I have used one Tilton unit to get an odd size (maybe 11/32) and it worked fine too. They are heavier than Willwood, cost more and are harder to find, though. I do replace all my fluid every two years and use only Castrol LMA fluid.
If I were having the kind of luck that you have, I would make a plastic shield for the area below the master cylinder. Just cut up a molded plastic box (or tupperware) and position it so it directs the fluid away from the painted surfaces. Done creatively, it can look pretty good.
RS
