Old 12-22-2011, 01:32 PM
johnkn johnkn is offline
I received the McLeod kit 75236. Opening the box, the overall size of the TO bearing looks small across the back where the retaining clips are (like the non-working SPEC TO bearing presently in the car) as opposed to a stock TO bearing for a 428 CJ with top loader that looks a somewhat wider.
The "U" on the CJ release lever is a bit wider than the standard FE lever. Anyone know if there a CJ specific TO bearing I should use when running a TKO?
The CJ lever looks like it tried to walk off the small SPEC bearing, part of my original problem. I don't want a repeat.
Thanks
