Old 12-23-2011, 03:57 PM
Gaz64's Avatar
Gaz64 Gaz64 is offline
mreid,
If you're planning on changing yours, I would suggest using the Viton rubber seals over the Teflon seals. I have seen the Teflon seals get hard or brittle and not seal as well over time. The Viton seals provide a much better seal.
Another vote for viton.
I use viton in every engine now, will never use teflon again.
I've seen too many failures; broken, split etc.
Gary
