Old 12-25-2011, 01:21 PM
greg schroeder's Avatar
greg schroeder greg schroeder is offline
Cobra Make, Engine: Superformance, Roush 427R-095, Pro Systems carb, 2" headers, Buckshot Racefab side pipes, 10s off idle start
If the plan is to look at the car and cause maximum confusion for others asking if it is real get a basic FE with old looking valve covers and old fashion fuel lines and stuff. Then you can make jokes about it being a real car along with evasive responses avoiding disclosure that the car isn't an original Cobra.
For me the plan was to go with a nice size engine that didn't kill the budget. I wanted the car to be very streetable cruising or a fricken hammer if the throttle is mashed and be able to make a casual start high 10s 1/4 pass without having to destroy the car launching hard. The Roush 427R stroker Windsor, hydraulic lifters, Victor Jr. intake, Pro-Systems carb and AFR heads seems to be the trick just like many of the packages out there. Get a good fuel delivery system and a set of Drag radials.
If the plan was to go faster, sure go for a 500+ cube big block or maybe a twin or single turbo small block stroker. That would be fun particularly if the engine was built as light as a Windsor.
The bottom line is you just gotta do what you like rather than what others like.
off idle drag pass, DA 750ft.
