  #23 (permalink)
Old 12-30-2011, 01:58 PM
Cashburn's Avatar
Cashburn Cashburn is offline
Backdraft Racing Dealer
Originally Posted by mreid View Post
So...I changed the carb, tuned the idle to 15" of vacuum with all four mixture screws at 1/2 turn out and still have the same problem! I pulled a plug that was brand new with only 1 hour of run time and it was black and sooty. The soot is damp and can be wiped off with a rag. I'm now thinking I may have the same issue Chris was having with the valve seals. The problem is that I can't road test the car as it falls over as soon as I give it gas. They are easy enough the change, but still are a few hours of work. Before I do that does anyone have any other suggestions? And Brent if you are reading this thread, would you use these seals?
COMP Cams 529-16 - COMP Cams Valve Seals - Overview - SummitRacing.com
Ford Racing sent those seals to us and they did not work. We are trying the Crane Cams seals (white) next. I don't think your issue has to do with the seals though...
IT'S NOT REAL. IT'S UNREAL.
VINTAGE MOTORSPORTS
