Old 12-30-2011, 11:39 PM
68pony 68pony is offline
Originally Posted by mreid View Post
I also now understand that some of the earlier 427w engines from Ford had high volume oil pumps with small oil return holes in the head, This caused the valve covers to fill with oil. Ford's tech line is closed until Tuesday and I hope to get some answers then.
Good luck mate, i emailed them about this very thing, high volume oil pump and poor drain back hole in the head can cause the top end of the motor to flood with oil, didn't get much back from them on that one, i was told by a work shop in the US ( i won't mention names) that changing to a standard oil pump can help and has solved some oil burn problems on these 427's he has fitted.
