Old 12-31-2011, 06:05 AM
mickmate's Avatar
mickmate mickmate is offline
Hey Doug, I used the machine screw type then tapped the hole. After tapping the holes into the glass I still had room for a nyloc on the bottom. A couple of them weren't quite long enough to get as far as the nylon but it worked out fine as they have more thread thru the body. You will have to remove your rear inner fenders panels that are pop riveted in to reach a few around the sides. While you're in there might as well position and attach some roof bow ferrules if you don't have them.
mickmate
http://www.actoncustom.com/
