Thread: 408W or 427W
  #33 (permalink)
Old 01-02-2012, 12:02 AM
Dana E. Dana E. is offline
Cobra Make, Engine: Superformance SPO2512 427W TKO 600/ NW Exotics 351 Cleveland/Tremec 3550-Sold
Go with the AFR head if your going the 427w route, in some cases the trick flow head, blykins knows best
I'm going with the Brodix KC 210 heads for a couple of reasons: the exhaust port location is close to the location of the Dart Pro 1 heads that were on the 393 so the exhaust should bolt up without work and the Brodix heads outflow the AFR's...at least according to the published flow charts for both heads. I'll probably have my machinist check them on his flowbench.
We have two of Keith Crafts 408W in our club. They make 530 plus hp and 540 plus tq. Coach Mike has several thousands of miles on his, three years of driving year round. No problems. Very street-able motors, meaning they idle correctly, do not over heat, no oil leaks, no problems. Just drop in and drive.
I picked up the last motor a couple of weeks ago. 408W 531 hp & 540 Tq, cost $8375. If you will add up the cost of the parts your going to buy and the machine work, you will spend close to $8000. Keith uses parts that he has proven will work
I don't doubt Keith Craft builds a nice motor, but I prefer, and I'm more than capable, of building my own. It's my therapy. The one and only "crate motor" I bought in my life didn't make it 175 miles. My machinist friends are great. They know I have the tools to check the work as accurately as they can....and I will check.
Thanks to some serious shopping and some good deals, I can build an all new Dart block 427, with a forged Scat rotating assembly, using Keith Crafts' Brodix 210 heads and his hydraulic roller cam for about the same price as a factory block 408.
As Brent suggested, going bigger than 427" would not really cost much more for the engine parts, and you could make more power. In my case, I already had the new manifold and carburetor from the 393, I didn't want to shell out the dough to have new headers made and I don't have enough room under the hood to use a taller intake manifold. If I was starting from square one, building a 460+ inch motor would be very tempting. All in all if this motor can hit close to the advertised power numbers, not come apart on the dyno, and last more than 175 miles, I'll be happy.
