Old 01-02-2012, 06:52 AM
spf2551 spf2551 is offline
Cobra Make, Engine: Spf Shelby alu block
Default 427 side oiler cam bearing.
Guys I need help with finding cam bearings for a Pond 427 side oilier block.
I order in a set but when I started to install them found them to be about .0140 wider then what came out of the block. Once installed the extra width would not allow the oil holes to line up on the first and last bearing. I purchased the bearings from the shop that I purchased the block from.
The old bearing are .0620 wide and have a part number on them F/M SP3208DR. thenew bearings are Dura bond and are .0760 wide with a parts number of FP 01
