Old 01-02-2012, 09:08 AM
Barry_R Barry_R is offline
The Pond block uses either Robert's specific bearing set or it can use the 1268M F-M set for the Genesis blocks. The 1268M is a bit narrower and will not require distributor clearance trimming. Both use the same OD all the way through the block.
And yes - we've seen a couple cam bearings walk in aluminum blocks - you need to AT LEAST use red Loctite, better is a dowel pin or small fastener in front of & behind the cam bearings to keep them in place.
Survival Motorsports
"I can do that....."
Engine Masters Challenge Entries
91 octane - single 4bbl - mufflers
2008 - 429 cid FE HR - 675HP
2007 - 429 cid FE MR - 659HP
2006 - 434 cid FE MR - 678HP
2005 - 505 cid FE MR - 752HP
