Old 01-02-2012, 02:24 PM
FIA-ERA FIA-ERA is offline
Cobra Make, Engine: ERA FIA 2008/351W/TOP-LOADER
With out a doubt the most stressful part of my Cobra's assembly!!! I drilled the holes out, tapped the screws in, sprayed the primer, tapped the holes out again, sprayed the paint, tapped the holes out again, ran a tapered tap through, then finally installed. Make SURE you use a "Fiber" washer underneath as it will help seal up the last little bit. Be careful too around support tubes. If it hits anything else your screwed, literally. Of course this is on a fiberglass car. I DID NOT like this part of the build. Everyone advice here is spot on too.
Regards, Matt
