  #30 (permalink)
Old 01-04-2012, 12:30 PM
DANGER DANGER is offline
Cobra Make, Engine: SPO 2644 Roush 427R
I'm running 500# springs, single adjust QA-1's, upgraded both sway bars and intalled the rear shock brackets. I had the 10mm bolts and noticed some wear after only a couple thousand miles.
The tires are Goodyear F-1's 35 - 315 - 17" rear and 45 - 255 - 17" fronts??
I have not replaced the ball joints yet.
I can tell you the bouncy ride of the 350# Bilstein's was down right scary... More than once I had my hands full hitting even small bumps in corners. The rear tires would rub the inside fender wells and the car would almost fell like it was changing lanes...
The overall ride is much firmer and almost a little to stiff. But the handling is greatly improved and no more rear tire rub... In my opinion money very well spent...
