  #32 (permalink)
Old 01-04-2012, 01:38 PM
dls141's Avatar
dls141 dls141 is offline
Cobra Make, Engine: LA Cobra / B&B 427 SO
Question Take the Turkey pan off
Originally Posted by petercory View Post
The Problem is the Turkey Pan, with it on, the scoop cant flow enough air for a 500CFM much less a 750 or 780CFM Carb! Do a full bore accceleration run and shut the key off at about 6000RPM and take a plug reading - They'll be black with the pan on. Take the Turkey pan off and do the run again - if the carb is jetted properly, the plugs will read perfectly! We proved this out while tuning for a Run & Gun many years ago.
So you're saying if I'm running an 850cfm holley on a 427 so I should take the turkey pan off.
