Old 01-05-2012, 06:27 AM
double-rr's Avatar
double-rr double-rr is offline
Cobra Make, Engine: HM-2005, Keith Craft 408W TKO 600 IRS
Default Master Cylinders
Seems Hurricane is supplying the compact master cylinders from Wilwood with their kits. The ones shown in the picture from Lampe's HM-2002 were longer and looked like they protruded below the foot boxes. The compact ones are shorter and do not protrude.
Here's a profile of the compact master cylinders without the heat shield.
You can see that there is a good bit of distance between the bottom of the foot box and the master cylinders. Something could of course be thrown up to hit/damage the cylinders or lines. I put 90 deg adapters so the lines are toward the top.
If necessary, a plate could be either welded or bolted to the bottom of the foot box to protrude forward to cover the cylinders/lines for protection. Bend an upturn on the front of the plate and should protect them pretty well. I'm not sure a plate is necessary though.
Hurricane is pretty fast in getting their kits out. I think mine was 6 weeks so your's should be ready soon. The wait was a killer for me too. Some guys wait a heck of alot longer from other manufacturers.
Russ
