Old 01-07-2012, 12:34 PM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by fordracing65 View Post
Is there any benefit to running a self tuning efi system, it seems to me that a tunable system would be a better choice, is the cost a huge difference?
Self tuning is really good these days. The ECU and associated software can self tune to the specs you provide. If you think it's a little lean or rich in one spot, you tell the computer to tune to a differant AFR
Originally Posted by Avmaviator View Post
Could you elaborate more on the issue? I have the same system. On the dyno we have a problem with high idling, which was solved by synching the throttle bodies accurately, and playing with the airscrews
Over the years I have discovered the proper synch is critical. If it's not spot on, no amount of tuning will make it run well. The balance has to be dang near perfect. I spent a lot of time getting mine set up correctly. I eneded up making some new linkage parts to get it exactly right.
Once you have the balance right, the tuning will be much easier, and the car will be a real joy to drive.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
