Old 01-08-2012, 01:45 PM
Stentor's Avatar
Stentor Stentor is offline
Cobra Make, Engine: CSX 4000; Shelby aluminum FE with 58mm IDAs
While I think the price is high, not based upon total cost, but current market value, the OP should realize that Dennis Olthoff is one of, if not the, best install companies/shops that one can hire in this country.
The install and final delivery of the referenced car is likely near perfection.
I agree with Rod--I've generally had good luck with the work that Olthoff has done for me.
Mrmustang provided good advice. It's an SPF with a lot of high-end options. Do some diligence to determine what's most important in a Cobra for you, which manufacturers are best for you, and the options that you want. Once you do this, if you still like the aforementioned SPF, then determine a fair price and make an offer.
Good luck.
