Old 01-09-2012, 10:06 AM
CHANMADD's Avatar
CHANMADD CHANMADD is offline
Being that you are in the States and drive on the right side of the road, run wires to the light and when you light the low beam the beam should angle , down and to the right, and on high beam straight ahead. The wire should run through a grommett which will prevent moisture from getting in.
