Old 01-11-2012, 04:51 AM
patrickt patrickt is offline
Default Naaah...
Originally Posted by Dangerous Doug View Post
Any reason why you guys don't give it a shot of ignition spray? Fires right up, runs the mech fuel pump, and keeps on going.
Only because I don't keep that stuff around. Now I have vague, vague, vague recollections of threads on other forums where starter fluid somehow got between the rings and cylinder walls, or something else happened, and it ended up doing more harm than good. Don't quote me on that. If I was ridiculously fanatical about it, I would pull the distributor, spin the pump counter-clockwise with my drill, put the distributor back in, fill the bowls up through the vents with a measured amount of fresh gas, and then spritz a bit down the top before I fired it up... but I don't. C'mon, FEs are really "war horses" in disguise. My FE will still be pulling out stumps long after I'm pushing them up.
