Old 01-11-2012, 10:02 AM
bliss's Avatar
bliss bliss is offline
I find using scrunched up black & white news paper works best of glass work.
Try it you wont look back
That does work, except Newspaper are currently recycled, and most are formulated with adhesives, which glass cleaners will break down leaving a tacky reside and paper ‘lint’ on the glass surface. The inks used and some chemicals can allow ink transfer to the glass. Newspaper inks are now water-based (unlike the older oil-based they will not shine glass) But they will stain your hand black (they dissolve with body heat) so be careful what surfaces you touch after handling newspaper (fabric, leather, plastic, etc) as they may stain.
Now this is a bit overboard, since newspaper does work - it all depends on the result that one is out to achieve.
