Old 01-11-2012, 10:45 AM
vector1 vector1 is offline
Cobra Make, Engine: jbl
i would not recommend starter fluid, especially with some of the higher compression engines, if it doesn't fire on gasoline vapors something is usually off.
i find that a couple dribbles of gasoline into the carb and a couple attempts at starting usually works fine, pumping the pedal to get the engine to run off the accelerator pump initially.
