Thread: Rear End Steer
Old 01-11-2012, 01:29 PM
Dwight's Avatar
Dwight Dwight is offline
Smile
Treblig, drove his Cobra over to my shop last week and let me drive it.
I think the upper and lower control arms are mounted to the frame to close together. Making them parallel, not triangulation. If the upper arms were mounted closer to the center of the car, I think it would stop the side to side movement. The rear end moves with the least amount of acceleration or deceleration.
If you look at his picture the uppers are mounted to the frame just above the lower mounting points. Is this to close together to prevent side to side movement?
You might be able to correct the problem with a pan hard bar.
Dwight
