Old 01-14-2012, 06:47 AM
Dwight's Avatar
Dwight Dwight is offline
Smile Oil Questions
What is the bypass rating?
Relief valve opening pressure?
Does the bypass opens at 14 psi allow the oil to bypass the filter? Then how much oil is really filtered? If our motors have 50 psi on the oil system how does this work?
I understand that the manufactory build a bypass into their filters because people do not change the filters and they clog up stopping any oil from passing thru. Thus lawsuit for a new motor, because I to dumb to take care of my old motor!
Dwight
Brand Motorcraft
Manufacturer's Part Number FL1A
Part Type Oil Filters
Product Line Motorcraft Oil Filters
Summit Racing Part Number ACF-FL1A
Oil Filter Style Canister
Height (in) 5.190 in.
Outside Diameter (in) 3.780 in.
Filter Bypass Relief Valve Yes
Relief Valve Open (psi) 11-14 psi
Anti-Drainback Valve Yes
Smallest Particle Filtered 20 microns
Maximum Burst Pressure (psi) 200 psi
Thread Size 3/4-16 in.
Gasket Outside Diameter (in) 2.800 in.
Gasket Inside Diameter (in) 2.422 in.
Gasket Thickness (in) 0.203 in.
Quantity Sold individually
Brand Motorcraft
Manufacturer's Part Number FL1HP
Summit Racing Part Number ACF-FL1HP
Height (in) 5.750 in.
Outside Diameter (in) 3.719 in.
Relief Valve Open (psi) 22 psi
Gasket Outside Diameter (in) 2.813 in.
Gasket Thickness (in) 0.328 in.
Quantity Sold individually.
