Thanks Treeve,
I have read thru ADR 31 and paragraph 5.2.3 on brake warnings simply describes what is needed. In summary the "handbrake" and "Brake Fail" can be the same light. The use of fluid level switches in the master cylinder reservoirs is permitted and there is no mention of a timed signal showing when ignition is turned on.
The seat belt must stay on for 4 seconds after ignition is turned on or when seat buckle is attached.
All good.
