Old 01-15-2012, 12:09 AM
Mando's Avatar
Mando Mando is offline
Hi Merv, both water points are usually threaded into the waterpump and should be easily removed using a good pair of multigrips. You can then install a plug. Why on earth would you delete the rubber hose joining the waterpump to the thermostat housing?
Regards.
Mando
