01-19-2012, 06:34 AM
Vic
Originally Posted by 750hp
ICE, I've always wanted a proper roots blown car and finally bit the bullet last year. Visibility in a Cobra might be an issue..
C'mon You have the perfect scoop for it !! was it really an issue!!...the only scoop i've seen bigger to yours was the WEINECK 780ci !!!
Originally Posted by OZCOBRA
ICE if you've had and love the 6/71 ....Have a dig around and look for a V6/71 same internals...but the base plate isn't there and you can mill out and down a Bronco Lower Plenum and then weld a mounting plate on for the case....
45 +degree Dissy ,modify an old echo Whipper snipper head
Also a few injection options and the best thing is it will all fit under a COBRA BONNET with a ever so slightly bigger scoop which I reckon looks better anyway!!!
It can be done!!!!
