Old 01-20-2012, 06:05 PM
patrickt patrickt is offline
Originally Posted by Silversmith View Post
Can these pin drive 15" rims (5 or 6 pin) from different mfg.'s ie- Superformance, era, csx, inter change with each other? Or as a rule; are they required to be used on org. hubs from each mfg.? As a rook to pin drive/hub set up's, thought I would ask.
I will speak only to the true, 6 pin drive system from ERA, since that is what I have. They use a different backspacing on the front wheels (ie, not original Cobra backspacing), so "no" you can't use them elsewhere without modifications. And I'm not even sure if you can get a 6 pin system from anybody but the "big three" (ERA, CSX, KMS).
