Old 01-21-2012, 04:13 PM
Modena's Avatar
Modena Modena is offline
Originally Posted by Philm View Post
Try starting your car and take off once you have suffient speed turn the key off, wait 3 seconds, turn ignition back on then clutch start your car.
Take it for a drive and see how it goes.
If this solves the problem give your battery a good charge, as when starting the voltage can drop to low and the ecu will go into limp mode.
You also may not have reconnected the battery properly creating a bad connection and when under load... Starting.... You get a huge loss.
Just a thought.
Phil
This is a great idea, never thoight about doing that. Just be careful - dont turn the key all the way off or the steering lock may come on!
Ben in AU
