Old 01-24-2012, 05:35 PM
Z-linkCobra's Avatar
Z-linkCobra Z-linkCobra is offline
Cobra Make, Engine: Everett Morrison, All aluminum small block ford.
Thank you Russ....I appreciate that.
Xavier, How much room do you need? As Russ stated the the taper is a very important factor in shortening your stacks. Russ needed about a 1/2" for proper clearance and his taper was just right for me to take a 1/2 out. If you are interested in having them shortened you can give me a call and have a caliper handy....I will need you to give me some measurements.
Gene
956-533-1205
" If it wont break em loose in 3rd gear, it aint enough power "
