Old 01-24-2012, 11:06 PM
lal Naja's Avatar
lal Naja lal Naja is offline
Cobra Make, Engine: Butler Cobra. 350 Chevy Engine, blueprinted, heads cc'd, ported, polished, manifolds matched, big valves, 1.6 roller rockers, TB Injected, mild cam, MSD crank trigger electronic ignition. TKO-600 transmission. XKE Jaguar rear. IFS by Fast Cars
SoulSurper. Congratulations on the build.
If you are using the Butler MGB steering column, 10" intermediate steering shaft and MGB front suspension, I have something that you may be interested. If you are not then it may not work for you.
It is a custom steel bracket that is fabricated to bolt to the frame near at the top of the steering shaft that comes from the rack. This bracket has a heim joint that will support the shaft and prevent lateral loads on the bearing in the rack.
If you are using a Fastcars IFS I also have a spare intermediate steering shaft.
Not sure what else I will have leftover, but I will post again when I know.
Arthur
