Mat I ask why??
D111 First name would be nice. How many miles are on the fluid? Are you having a problem with the rearend of trans shifting? If not leave the fluids alone. If you are racing, that's a different story. Under semi normal driving conditions 25K to 50K miles is a normal change unless for abuse. If you are having a shifting problem or posi issues then there might be something else wrong and adding new fluid will only fit the issue for a short time and may do more damage than good Fine out what the problem is. Talk to BDR first before changing things. I am not saying that it's not a good idea to do if you have a new trans and rearend installed in the car and have 500 miles on it. this breakin will get all the partials from machine work done in both assemblied that didn't cleanout. Good luck Rick L. Ps If there is a warrenty on either part, You better be 100% sure you are using the correct replacement fluid. Wrong fluid WILL void warrentys. Calling BDR would be the best bet.
