Old 01-29-2012, 11:16 AM
wrench87 wrench87 is offline
Cobra Make, Engine: factory five mkIII roadster 445 fe quick fuel 750 q series,irs
the engine is done , i just painted the block the other day a lot harder to do when the engine is assembled it took me 1 1/2 hours to tape every thing off, i have been out of work so no money for a new tko 600, i have a 3550 on my 342 now.
basically it is a 72 390 block .030 over steel 4.250 crank, eagle 6.7 h beam rods, diamond pistons slight dish, keith craft stage 1 heads with a little more work done, crane t bar lifters, erson rockers, comp hydraulic roller .598-.618 lift 230 238 duration 112 lobe center, ported performer rpm manifold, ram aluminum flywheel, big block chevy performance clutch. i am running a 400 hp 342 stroker with mass flo fuel inj, i have to change the fuel pump in my fuel safe cell, select a carb pull the efi harness out and just wire a new circuit for the fuel pump and install a msd 6al box.
