Old 01-31-2012, 12:26 PM
Blas's Avatar
Blas Blas is offline
Cobra Make, Engine: SPF#0760
Something maybe easier to find is:
Permatex® Hylomar® Universal Blue Racing Formula Gasket Dressing & Flange Sealant
Non-setting and non-hardening at elevated temperatures. It withstands rapid changes in temperature and remains flexible and tacky even at high temperatures, allowing repeated disassembly and reassembly in high performance applications. This no-run formula seals surface imperfections on machined flanges and is vibration resistant. Temperature range of -60°F to +500°F (-50°C to +260°C); resists engine fluids, including water, coolant, gasoline, lubricating oils, kerosene and some refrigerants.
Suggested Applications: Thermostat housings, differential coverings, hydraulic drives and motors, gearbox assemblies, intake manifold assemblies, oil, fuel and water pump housings and seals, fuel injectors and fuel pumps, transmission and torque converter seals.
SPFWiringDiagrams@Comcast.net
