Thread: Called to Task
Old 02-02-2012, 01:16 PM
jetsbaby's Avatar
jetsbaby jetsbaby is offline
Originally Posted by Karl Bebout View Post
Hope you have better luck this time. Wasn't that where you were going when your tie rod broke? (You should take Adriana out to the Marina at Saguaro Lake. Much better food and the view is excellent.) Also, had a thought about that nasty Cobra wreck that's been going around, on line. Wondered if the car had been a Contempory with the same faulty engineered tie rod issue? The car seemed to just suddenly make a hard turn, at high speed.
The car was a Backdraft Cobra...A rear suspension arm/or bolt had failed at 130 MPH and caused the spin...When he hit the deep gravel at the track, which was at the end of a turn she flip like nine times..Complete 360's but landed upright..And the roll bar never touched the ground!!! The driver used up all of his luck on that accident and is very lucky to be alive..
