Old 02-05-2012, 08:23 AM
bobcowan's Avatar
bobcowan bobcowan is offline
Originally Posted by sambo View Post
Any thoughts on whether 10 degrees hotter is going to make a very big difference to pollutants at the tail pipe? I would've thought it was minuscule compared to what the cats are achieving.
Yes, it does. That's the whole point of the factory using the higher temp. The cats need to be at a pretty high temp to do their job. Getting the chamber temps up there helps the cylinder charge to burn better, and then puts more heat in the cats.
When it was on the dyno, did they measure CO? Sometimes you can get a pretty good idea from the dyno run.
If the engine is tuned well, you should be able to pass a smog test in this country. But (obviously) I don't know much about your country.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
