Old 02-06-2012, 04:53 AM
sideshow sideshow is offline
abs and crusie is easy and hard at same time
abs u need all 4 wheel reluctor rings fitted and sensors etc etc
cruise u need the buttons off the steering wheel
if u use factory ford steering wheel its easy
but if u want different wheel then u need to look at the fiddly things
dash is another fiddly thing
ford speedo works of abs
no sensor on gbox
so if u dont run abs u need to look at that
ford tacho works of canbus
so if u dont run ford dash u need module to get rpm to aftermarket tacho
as theres no rpm wire on ecu
just ring the guys at castle autos or bpt if u need anything done
theres ****loads of guys doing the sct boxes these days
friend of mine is sydney is an agent
or just buy the sct box load up the software learn how to use it
turn off security yr done hehehehe
my website
www.sideshowsperformancewiring.com.au
