Old 02-08-2012, 02:51 AM
sideshow sideshow is offline
just use battery cable called 2 b & s or electra cable ebs2
this cable should just fit inside the battery lugs size 35
anything bigger is overkill
its normally not the cable that stops car from starting
its the joins and connections so make sure u crimp properly
dont solder the big joins as it looks fkt then heatshrink over crimp
so u get less dirt inside
and what i told all the guys who had cobra that we wired was
front left and front right and rear right and rear left weld a big bolt
maybe 8mm or 10mm bolt to the chassis in a good out of the way spot
this should be used as an earth
ive seen guys uon cobras use self tapers and **** or even rivets hehhe
so if u have a welded bolt which will be like an earthing stud u will have less problems
so u can earth yr lights and blinkers etc etc
also maybe 2 small ones under dash
just makes it nicer and u know where yr common earth are
my website
www.sideshowsperformancewiring.com.au
