Thread: Hot side pipes
  #53 (permalink)
Old 02-08-2012, 08:45 AM
patrickt patrickt is offline
Originally Posted by redeye13 View Post
I have a Clasic Motor Cobra that I need a set of Ford small block headers. I have searched but to know advail. Does anyone know where to get them??
I don't know that car. If nobody is famiiliar with an "off the shelf" set of primaries that fit your particular car/sidepipe configuration, then the next step is to use one of the "put together" tube kits that you use to mock up and fit between the heads and the sidepipes (so they don't hit the steering column and other stuff), tack it all together, and then give those to the fabricator and they'll make the real thing for you.
EDIT: Here's an example from a quick Google: Custom Headers Built To Your Specifications
