Old 02-11-2012, 03:55 AM
Default Plugs and are done
Rwillia4 Rob the O2 and plugs are done. Glass beading the plugs will clean them. Question, what is the gap you are runninng at?? You have a good spark to a bad plug. Try running at .045" to start. If the O2 sensor looks like this,(plugs) it is trying to lean out the A/F readings to get to the 14.7-1 ratio. Don't play with the ECU until we fix the other problems. Unless you see something wrong with timing or loose distributor, don't touch it. Need to fix 1 thing at a time, this is the main reason alot of guys get lost when an FI car is not running right. Rick L. Ps thanks for the short film, makes diag alot easier to fix.
