  #21 (permalink)
Old 02-13-2012, 07:48 AM
kevins2's Avatar
kevins2 kevins2 is online now
Cobra Make, Engine: ERA #795 427 S/C completed Jan. '14 - '68 FE 427 side oiler
I had the same problem you described earlier with not being able to get a screwdriver all the way through a filter. I was able to drill a hole through the center of the filter a bit smaller than the shaft of the screwdriver and then could get the screwdriver through by tapping it with a hammer. Then I was able to grasp the screwdriver on both sides of the filter and it came loose quite easily then, even though the hole was at an angle due to space restrictions. A set of extra long drill bits have come in handy for lots of uses over the years.
Good luck with this.
Regards,
Kevin
