Old 02-13-2012, 11:24 PM
RestoCreations's Avatar
RestoCreations RestoCreations is offline
Cobra Make, Engine: Kirkham 289 FIA, 363 Stroker
Originally Posted by John Martin View Post
I had on go bad , Fixed one for a friend , saw one being fixed at a shop .I keep a spare. should read 400 ohms Msd should let it be known about a bad batch . And let you send in the old for a new one ...actually , they probably would .
I was informed by the MSD tech that the OHM test is just a guideline and that it doesnt actually tell you if the pickup is bad. I know it worked on the first one that went bad, but i havent even tested the second one because i know its bad. I had the car running with a mallory before i installed the MSD and i have spark coming out of the coil wire when i short the green and violet wires on the box together, so it must be the pick up. I hope there isnt something wrong with the box that is frying the pickups.
