Old 02-14-2012, 12:41 AM
TUF-427's Avatar
TUF-427 TUF-427 is offline
Cobra Make, Engine: Drb,5.6 8tb Windsor,TFS heads,Dart Shp,TKO600 ,4link 9in diff.Ford acid rush Paint,convopro wheels.
Hi Greg,
Pretty sure Scott at Venom has the rear mould the right shape for a harrison.....
then Attached to body with Tennax fasteners and the two Mg teardrops, and a steel or alloy bar to reinforce as Merv has Suggested..
You will Also have to consider if you want to use the 1 or 2 piece windscreen header,both with pros and cons...
Peter..
Horsepower sells engines,Torque Breaks 9 inches...
