  #47 (permalink)
Old 02-15-2012, 08:49 AM
D-CEL D-CEL is offline
Cobra Make, Engine: SPF 239
Here is a couple of shots of the bar and the vents.
Vents: I got some stainless steel wire mesh (304) in a couple of different sizes from McMaster-Carr. Ended up using the 8x8 mesh (.020 wire dia. .100x100 opening) made a wooden buck and formed the mesh over it. I’m having a pair of mounting rings laser cut from .125 thick sheet stock. Planning on a bunch of (tiny) tack welds. We will see if that works out. Then it will be riveted to the underside of the hood. (You can see the template for the mounting ring on the passenger floor) You can also see where we cut and moved the inner wheel-well for tire clearance (pass side)
