Old 02-15-2012, 10:33 PM
bobcowan's Avatar
bobcowan bobcowan is offline
First off, there's no such thing as a self learning EFI. They're a lot better than they used to be. But you still have to know what you're doing. The computer can process a lot of data, but it's not very smart.
The less expensive EFI's use a central throttle body with injectors. It's essentially an electronic carb with a wet manifold. IMO it's a step up from a carb. But not nearly as good as port injection. You get what you pay for.
Think of it like a carb that's really easy to tune. You don't even need to open the hood to adjust the mixtur.
The $1,400 doesn't always cover everything you need - tuner, O2 sensor and controller, high pressure fuel pump, etc. Just like a carb doesn't always come with everything you need - linkage parts, studs, kick down cables, slosh tubes, etc.
.boB "Iron Man"
NASA Rocky Mountain TTU #42
www.RacingtheExocet.com
